ps3 and sky broadband
Posted: Sun Apr 20, 2008 2:15 pm
by dpower
whenever i try to connect to my wireless it almost gets there then says it has timed out. dunno what that means...anybody???
Posted: Sun Apr 20, 2008 10:06 pm
by CymruPolo
Do you mean when you try to get the PS3 to connect using the connection test feature? Or when you're trying to sign in to PSN with your email address and password?
Posted: Sun Apr 20, 2008 11:19 pm
by polo-sib
Timeout, prob the router not letting you access what you need due to its built in firewall. Best bet is set a manual IP on the PS3 and set that IP as a DMZ (all a DMZ is, is a specified IP address with all open ports).
Posted: Mon Apr 21, 2008 12:57 pm
by Gra-GT
How close is your router to your PS3
I had this problem originally, and it turned out even though the signal strength was fine (at about 20% or so) it was still too low. I moved the router down stairs closer to the PS3 and it has worked fine ever since :D
Posted: Mon Apr 21, 2008 5:49 pm
by dpower
thanks for that. my consoles in my room and the routers downstairs, should probably move it like u lot say.
Posted: Mon Apr 21, 2008 5:58 pm
by pip_polo
buy an xbox 360 :lol:
