car starts "lumpy"
Posted: Sat Apr 26, 2008 1:26 am
by JoeG07
recently when i start the car, starts as normal, then the revs drop right down, it shudders violantly and then stalls. is usally ok if been driven just morning starts, i have to sit there revving the cr@p out of it or it stalls. any suggestions? I'm suspecting the airbox has something to do with it but really no idea
Posted: Sat Apr 26, 2008 2:07 am
by stevie boy
mine does this aswel.just somtimes though.
Posted: Sat Apr 26, 2008 8:17 pm
by LeMeph
could be dirty throttle body or new airfilter, plugs or leads... long list.
When was the last service?
Try resetting the ecu. That sems to solve alot of stupid problems so im now recommending that to everything... even a broken gearbox....
Posted: Sun Apr 27, 2008 5:38 pm
by NOZ
LeMeph wrote:Try resetting the ecu. That sems to solve alot of stupid problems so im now recommending that to everything... even a broken gearbox....
lol
Posted: Sun Apr 27, 2008 8:47 pm
by JoeG07
had a service last week hasnt sorted it
Posted: Mon May 05, 2008 4:01 pm
by Dan1587
LeMeph wrote:could be dirty throttle body or new airfilter, plugs or leads... long list.
mine used to do this what i did was took the airbox off, got some fuel injection cleaner started the engine and sprayed it down the throttle body till it was almost clean, now she starts first time everytime, have had to do this procedure about once a month thou! im guessing the throttle body is on its way out, could it be a sensor, i have a spare one its just getting time to fit it!!
thinking about it, has anyone fitted one here? is it hard?
thanks
Posted: Tue May 06, 2008 12:25 pm
by NOZ
TEMP SENDOR perhaps!
A nackered one will give a false reading to the ECU, which can't cope with the erratic readings the temp sender gives. This results in the ECU trying to compensate fuel mixtures etc for the readings its given. So basically it goes burserk trying to keep the car running and a wrong mixture causes the car to stall.
Its one of the issues with erratic revs
