Drilled Brakes???
Posted: Fri May 16, 2008 12:51 pm
by kelly84
Im looking for some drilled & vented brakes, any suggestions where to get them from and any recomendations??
Posted: Sat May 17, 2008 4:22 am
by Tim_GTi
I've heard black diamond are good.
http://www.venommotorsport.com/manufact ... gory=Brake
You could also get your existing ones done if you wanted.
Posted: Sat May 17, 2008 6:14 am
by kinder
i use tarox dirlled and grooved on the front with mintex fast raod pads and there are great
Posted: Sat May 17, 2008 1:29 pm
by tegwin
I wouldnt want to fit disks that have been drilled by a chap on the corner.....
Drilled disks, if they are not done properly can shatter leaving you with no brakes and bits of brake disk lodged in your engine lol!
Posted: Tue May 20, 2008 11:18 pm
by LiverpoloGTi
I've done about 12k miles on a set of
these from ebay although it doesnt say on the listing the discs are actually made by Lockheed (well at least mine were) and I've been well happy with them not bad at all for £70.
As for pads I chose Ferodo DS Performance which are superb albeit a little bit squeaky sometimes.
Posted: Wed May 21, 2008 6:46 pm
by Rupy
Just get a 10mm drill bit and make a few holes
On a more serious note...get some G60 carriers and upgrade to a 280mm set up with standard discs. Much better tbh. The Gti callipers are big enough to hold the 280s so all you need is discs and callipers
Posted: Mon May 26, 2008 12:41 pm
by Reeyad
LiverpoloGTi wrote:I've done about 12k miles on a set of
Hi there,
Check the link you posted what fitment did you use for the polo also did you get rear disc as well.
Thanks.
