Replacing discs and pads, simple?
Posted: Tue May 27, 2008 7:57 am
by IansMusical
Hi Guys,
Am I right in saying replacing discs and pads on the front wheels for a 9N1 Polo is really easy, 2 bolts on calipers, 4 screws on discs or is there more to it?
Thanks,
Ian
Posted: Tue May 27, 2008 8:16 am
by panda
think there's only one screw per disc pal
Remember to take the fluid resevoir cap off because you'll need to wind back the piston to get the new pads in.
Posted: Sun Jun 01, 2008 6:02 pm
by pidge87
On the fronts you DO NOT 'wind' the pistons back in.
You simply push them in!
Only rear caliper pistons have a thread requiring them to be 'wound' in in an anti-clockwise fashion
Posted: Tue Jun 03, 2008 8:13 pm
by Jamo
Yep - only one screw per disk holding it in place... do take the reservoir cover off - and make sure you check it occasionally as you squeeze the front pistons back in. If you squeeze them in too quickly you may force the fluid out over the top - its very unlikely but it would ruin your paintwork inside the engine bay! When re-assembling, it pays to give the caliper a good wire brushing to get any loose surface rust off - then apply anice thin layer of copper grease to the part that the pad sits on. Oh and also on the metal back plate of the pads. If you've got alloys, it pays to grease the mating faces of the wheel and hub too - because they can stick together like an absolute bast***!!
Have fun - should take about 30 mins.
Posted: Wed Jun 04, 2008 7:54 am
by RUM4MO
pidge87 wrote:On the fronts you DO NOT 'wind' the pistons back in.
Are you sure you don't mean clockwise?!
Posted: Wed Jun 04, 2008 8:37 am
by IansMusical
Hi Guys,
Thanks for all your advice on this one and at least it isn't a complicated job to do
Does it have to be copper grease or will normal stuff be ok?
Thanks,
Ian
Posted: Wed Jun 04, 2008 10:22 am
by pidge87
Yep
Posted: Wed Jun 04, 2008 7:34 pm
by GaryUK
This has reminded me I need to change my front brake pads.
Where is the best place to buy them (preferably online) and what are the options
Posted: Wed Jun 04, 2008 7:46 pm
by RUM4MO
IansMusical wrote:Hi Guys,
Thanks, Ian
Yes it should be copper grease - just a light covering - not too much or it will get thrown outwards when the hubs are hot and the wheel turning quickly - and that means very messy wheels! One of the original uses for copper grease was for coating furnace bolts - the stuff I still have 30 years on is called Copaslip - it only started getting used with disc brakes about that time - and now its also used sparingly to lubricate and provide anti seize properties to spark plugs especially when used with aluminium cylinder heads. Actually now some "quality" brake parts manufacturers suggest only using "their" new greases that are not metal loaded because of corrosion problem when used with dissimilar metals - but I've still got about half a tin left, so it will see me out!!
Posted: Wed Jun 04, 2008 7:51 pm
by RUM4MO
GaryUK wrote:This has reminded me I need to change my front brake pads.
You can get original equipment manufacturer's stuff like Pagid and Textar online postage free from GSF. Better to do your homework first on the TMD-Friction website (owners of the Pagid and Textar names) VW fit Pagid on the front and Textar on the rear - can't say why though! Maybe you should check your disc thicknesses also as they don't last too long!
