Car pulling to left but alignment is OK???
Posted: Thu Jun 19, 2008 6:23 am
by Orothon
My car has been pulling to the left for a while now so when it was in for its MOT yesterday I thought I'd have the alignment checked. The wheels were aligned but upon driving it home I found it still pulls to the left. Driving down a straight road with no camber the steering wheel rests naturally in a position a few degrees anti-clockwise from striaght on, causing the car to pull slightly to the left.
Anyone any ideas what could be causing this?
Posted: Thu Jun 19, 2008 11:46 am
by adam_0612
so tracking has been done?
i dont know but you might need camber/caster doing?
also have you checked tyres are evenly inflated?
Posted: Sat Jun 21, 2008 6:53 pm
by ihpj
Had this problem on a Vectra once upon a time - turned out to be the Pirelli P6000 tyres and the tread these tyres had. They just seemed to 'read the road' that way and pull to the left (have a left bias if you will) - changed the tyres problem solved.
I know how frustrating it can be. As an aside, just check to see that you have exact same tyres on each axle with matching tread depth - some tyres can be overly sensitive to any variations.
HTH!
Posted: Sat Jun 21, 2008 7:02 pm
by pip_polo
swap back tires with front.
my dads volvo did this with tires i scrubbed on one side.
Posted: Mon Jun 23, 2008 6:53 pm
by whitegtipolo
mine does slightly to the left ?! going awsome for full wheel alignment anyhow ill let ya know if it changes anything!
