UK-POLOS.NET - THE VW Polo Forum • Exhaust Emissions Warning Light
Posted: Fri Jun 27, 2008 8:05 am
by Overseer
Had this light come on last night, after driving around most of the day. Car seems to drive/sound fine, so I'm not quite sure there is a problem.
I did a search and came across a thread saying I should be filling up with 98 RON petrol - oops, didn't know that. Could this be the cause or is it something?
I'm going to Sheffield tonight for the weekend (about a 2 hour drive) will I be ok to drive?
Cheers if anyone can help
-Miles
Posted: Fri Jun 27, 2008 8:10 am
by Overseer
Oh, by the way. The light is on constantly, not flashing like the manual says.
Posted: Fri Jun 27, 2008 9:11 am
by tegwin
Wouldnt panick.... And no, the type of fuel should make no difference...
I used to use high octane fuel, but since the prices have gone crazy....I dont!
Possibly a lambda issue..
The only way to figure this out is to get VAG COM plugged in!
Posted: Fri Jun 27, 2008 9:23 am
by Overseer
tegwin wrote:The only way to figure this out is to get VAG COM plugged in!
Case of going to VW?
..and driving to Sheffield for weekend would be ok?
Posted: Fri Jun 27, 2008 10:05 am
by tegwin
Provided your engine temp is fine, and your oil looks ok... and the engine runs fine..
I wouldnt worry too much....drive to sheffield...perhaps dont try and hammer the engine..
But yes, go to VW, or buy the VAGCOM....
Posted: Fri Jun 27, 2008 10:40 am
by LiverpoloGTi
I've had that light on for over 2 months now!, every now and again it goes off for a short while. I've got so used to seeing the light the dash looks weird when it's not illuminated.
Oh yeah and the car sailed through its MOT emissions test with the light on. Drives just as it always has done and mpg doesnt appear to have suffered, so im not too concerned about it at all.
Posted: Fri Jun 27, 2008 5:16 pm
by Overseer
Well the light has strangely turned itself off now.
After spending most my day at work searching the forums about the issue, I think I'm going to try and use V-Power, to see if it makes any difference.
Fingers crossed it stays off.
Posted: Fri Jun 27, 2008 7:53 pm
by 92 rocks
more than likely down stream lambda....
Posted: Sat Jun 28, 2008 10:09 am
by R.I.T.B
Mines doing the exact same thing has been for around 6 weeks, been into VW and they said its the lamda sensor. It triggered five faults-something like, running rich, low on performance, low on oxyen etc. All related to the one sensor, it's about £200 i think and i'll be getting mine booked in shortly. As said its fine to drive unless the light starts flashing and just dont rag your car.
Posted: Sat Jun 28, 2008 3:51 pm
by 92 rocks
£200 you should be able to get a universal one for less than 50 notes, the job is a doddle, think they are a 17mm ring spanner disconnect old wiring and cut, remove old sensor, fit new sensor, resolder wiring from new sensor to old loom and job done, the light should clear itself...
NB remove and fit when stone cold!!!
Posted: Sat Jun 28, 2008 6:47 pm
by Tim_GTi
£200 for a supplied and fitted lambda sensor?
Posted: Sun Jun 29, 2008 12:26 am
by R.I.T.B
yeah thats how much the bloke said as a rough price but i need my exhaust re-weldin aswell so that could have bumped it up. how much should it be????
Posted: Wed Jul 02, 2008 7:16 pm
by Tim_GTi
I dunno I've never bumped into a legit quote, it just shocked me how much it cost!
Posted: Wed Jul 02, 2008 8:15 pm
by bbspolo
02 sensor 4sure!
get one from german and swed they sell the same ones as vw think there around the 20-30 pound mark!
o and dont let anyone charge u more than 20 quid 2 fit it! (its a ten min job on a ramp!!!)
Posted: Wed Jul 02, 2008 8:31 pm
by Mouse_GTI
It's definately a sensor, one of the most common sensor failures in all modern VW's
