UK-POLOS.NET - THE VW Polo Forum • Camshaft sprocket
Camshaft sprocket
Posted: Tue Jul 08, 2008 6:33 pm
by ckelly0172
Hi all....
Just doing a head gasket on my old 1.05 '93 polo and having real trouble removing the camshaft sprocket... Made myself a pulley holding tool, just as haynes mentions but the thing won't budge....!!
Is the bolt a right hand thread, ie. turn anti-clockwise to loosen? don't wanna be shearing the fecker off!!!!
Also, is it easier to leave the carb on adn remove it with the head, haynes states to remove before but it looks easier to leave alone?
Any advice greatly appreciated.
craig
Posted: Tue Jul 08, 2008 10:46 pm
by ckelly0172
also.... does the dizzy have to come off????
cheers
Posted: Wed Jul 09, 2008 5:33 pm
by steveo3002
its a normal thread bolt...so anticlockwise to loosen
i leave the manifolds,carb and dizzy on...can be left on if its a simple gasket swap or easier to dismantle once off the car
you might need a helper to lift it all off...its reasonbly heavy
Posted: Wed Jul 09, 2008 6:14 pm
by ckelly0172
cheers stevo,
finally removed the bolt, think a proper holding tool would've been easier, but at 65 quid glad i used my own!!
left them all on, much easier... Now removing the crank pulley was a b***h, not enough room to slide it past the crank bolt and inner side wall, crap design!!! to lever the engine to the side with a huge 2x4...!!!!
Posted: Thu Jul 10, 2008 9:44 am
by steveo3002
i take the alternator and its mount off...then raise n lower the engine a bit on a jack
Posted: Fri Jul 11, 2008 2:27 pm
by ckelly0172
Right, finally got it all back together after a week in between all the rain storms... gotta luv the british summer!!!! anyhow, all seems fine timing wise, however am getting a squeal that increases with the revs. Coudl this be the water pump if the timing belt is too tight?
cheers
craig
Posted: Sat Jul 12, 2008 9:18 am
by steveo3002
yeah could well be the pump ..it will kill the pump bearings in no time if its too tight
its common practice to fit a new pump when you do the belt...as if it siezes up the belt will come off
