UK-POLOS.NET - THE VW Polo Forum • Flashing Coil
Flashing Coil
Posted: Thu Jul 17, 2008 10:21 am
by Mark Boy
Hi there everybody,
My Polo 9N 1.4 Tdi has started to flash its orange coil light at me. I did some reading and found out about the brake sensor problem, and that it could be causing it.
So i checked the brake lights and all would appear fine :?
Is it possible that it could still be an issue with this sensor, even though it seams to be working normally? Or is it likely to be something more sinister :(
I don't have VAG COM so I can't check the error codes myself.
Mark
Posted: Thu Jul 17, 2008 5:09 pm
by pip_polo
is it your brake wear warning light.. meaning your front pads are worn to the limit..? if so they will need replacing
Posted: Thu Jul 17, 2008 6:05 pm
by TDI_Burd
i have the 1.4 TDI 9n and mine started to flash at me too the coil light that is and it turned out it was my brake light switch underneath the brake pedal basically i drove 100 miles with no brake lights lol
I think the brake light switch cost me few quid from dingbro isnt a dear part if u change it just incase it is still faulty
Posted: Thu Jul 17, 2008 8:25 pm
by Mark Boy
Thanks for the replies. I managed to get the codes read and it is the brake switch.
I also have all the usual heater flap faults and, 00898 Control Circuit A/C compressor, 010 - Open or Short to Plus. Anyone any ideas what causes this.
Mark :?
