UK-POLOS.NET - THE VW Polo Forum • fitting my door speakers
Posted: Fri Aug 01, 2008 6:18 am
by rick
hi,
i need some help i've got my speakers n components in but were can i feed the amp speaker wiring throught to the door for the crossover??
thanks
Posted: Sat Aug 02, 2008 5:44 pm
by davieo_04
Alrite Man, if it is the front door cards you can just feed the wire through the "rubber tube" which runs into the door from the car near the hinge point. There is already wires running down that for the c/l an e/w if your lucky enough. Interference shouldnt be a problem here!
Posted: Sun Aug 03, 2008 6:13 am
by rick
i opened the tube up and the theres a plug which attaches the door wiring loom to the car.
Posted: Sun Aug 03, 2008 12:31 pm
by Supraking
i do believe there is also a hole tho below the plug bit? when i did my mates there was already some speaker cable running through it
Posted: Sun Aug 03, 2008 1:06 pm
by h4r1s
you can drill through the corner bit which is empty, and feed the wire through that
Posted: Sun Aug 03, 2008 5:18 pm
by Tim_GTi
Take it this is for a 6N2?
You can do what Haris said, or actually disconnect the OEM wiring and connect your wiring to the plug.
Or for the wasiest option, and if your system isn't of astounding quality, just link your wire to the OEM wire further up the line.
Posted: Mon Aug 04, 2008 7:59 am
by rick
the system i've got in is realy good, so i'll hav a look at what is the best way..
thanks for the help
Posted: Mon Aug 04, 2008 6:52 pm
by Tim_GTi
What are you running?
I'd suggest Haris' method then, just be careful. there's alot of wiring there thet will c*ck right up if you disturb it.
Posted: Tue Aug 05, 2008 6:17 am
by rick
i'm runnin a orion hcca 15" then i got infinity kappa components
Posted: Sat Aug 09, 2008 4:08 pm
by davieo_04
nice kit, was going to buy a 12.2 hcca orion and components of caraudiodirect cause they were all reduced down but there was none left! whats it like?
Posted: Mon Aug 11, 2008 7:01 am
by rick
its 4 major bassheads... but the only thing is powering it, defo need a second battery.
Posted: Mon Aug 11, 2008 1:06 pm
by davieo_04
do you think so? i though you might have got away wityh a bigger altenator? have you built it into the box yet?
Posted: Mon Aug 11, 2008 7:00 pm
by rick
yh i had a look into it but for the money they asked i thought i could use it some where else on the car.
Posted: Mon Aug 18, 2008 4:07 pm
by davieo_04
true.. id say a power cap would help the whole thing quite a bit. \There not too badly priced either!
annoyed
Posted: Thu Sep 11, 2008 3:12 am
by gurdain
hi everyone
been on these forums for a while researching but this is my first post
im running a nice jbl cs12 in my boot with an alpine amp
recently decided to change factory speakers
first i got fusion encounter coaxials which paired with the front factory tweeters sounded way too airy and lacked depth
i replaced them with fusion cm-65 components (yes, im a budget guy)
which are rated at 70watts rms.
spent ages with that pdf document taking off door panels and drilling a hole for the new tweeter, disconnected old tweeter and mounted crossovers and finished to find the sound is crap and doesnt go as loud as before
my question is - would an amp improve this and where would i mount a second amp since the wires from the door would need to go to the amp and then the output of the amp to go to each crossover
cheers
