Feeler, modified 1.6AEE, bike carbs, pics added
Posted: Sat Aug 16, 2008 3:56 pm
55000miles, but engine has done under 2000miles since work done, 1.6 AEE, proffesionly worked head with ports opened, polished, and the heads been skimmed, new valve stems, oil seals, and valves lapped in, Newman cams 272 degree camshaft, vernier adjustable pulley, oil pump reconditioned (for saftey not because it had failed), all bearings checked, oil has been changed and checked for swarf ect twice uring running in and has been fine, currently running injection, but have got manifold, R6 carbs, R6 fuel pump, modified engine loom, and ignition system, if wanted. Engine is currently in a 6n mated to AEX (1.4) gearbox (not included), very fast acceleration, easily keeps up with much larger capacity cars, haven't even been flat out in it yet but with 3 people in the car managed 115mph, with 2500rpm-3000rpm left (and was still pulling, my balls wernt big enough!). make me an offer! will, cheers for looking
