ET??????
Posted: Wed Aug 27, 2008 11:27 pm
by polospeed
Anyone know what the ET is on a set of tt comps? Need to know what spacers I should buy if any. Cheers
Posted: Thu Aug 28, 2008 9:03 am
by david burton
32mm I believe, or thereabouts. You can buy 10mm spacers for the rear but not many people put them on the front.
Posted: Thu Aug 28, 2008 8:56 pm
by polospeed
Cheers david, I was thinking about 10 or 15 mm spacers on the back lol. What kind of finish is that on yours? They look well nice
Posted: Thu Aug 28, 2008 11:41 pm
by chewy
I`v got 10mm spacers for the rear and 5mm for the fronts for when I fit my comps
Posted: Sun Sep 07, 2008 9:05 pm
by lytebyte2002
just a quick question about comps. was gonna buy myself a set but i trial fitted one of my mates and the bore of the alloy was so tight it took so much effort to get the alloy off. Is this the same for everyone elses 9n? cos i would be so annoying if u got a puncture and was on your own getting it off.
Posted: Sun Sep 07, 2008 9:23 pm
by chewy
My 16" Barcelona alloys are tight as hell and they are standard
Posted: Sun Sep 07, 2008 9:40 pm
by lytebyte2002
obviously doesnt matter that much then. i just thought it would affect the car. cheers mate.
Posted: Tue Sep 09, 2008 11:22 am
by david burton
My finish is diamond cut and lacquered by Pristine Wheels. I've had them on the car for over 25k miles and 2 winters with no corrosion to speak of. Very pleased.
The centre bore is often very tight if either the wheel has been refurbed (thicker paint) or there is rust on the centre of your hub. A wire brush or screwdriver on this rust will help, and if it's your alloy that's been refurbed you'd have to sand the centre bore.
But if it's just tight, then if you "screw" the wheel onto the hub it will be easier than just trying to push it on. Mine are similar but sit flush once they are tightened up.
