UK-POLOS.NET - THE VW Polo Forum • hello, anyone help me please
Posted: Thu Aug 28, 2008 9:19 am
by clarkson
hi just wanted to know what the best filler to use,
i want to fill the gap where the license plate is, if anyone could help or give me tips like best way to fill it and what stuff to use, i would be very gratefull
very much appriciated thanks
Posted: Thu Aug 28, 2008 10:03 am
by 8080
Assuming you're referring to the recess on the boot... that's a job for a bodyshop. A metal plate will be welded into the recess. It's too big an area to fill, whatever filling method you use it would soon crack / sink.
Re: hello, anyone help me please
Posted: Thu Aug 28, 2008 10:04 am
by Torq-Al
clarkson wrote:hi just wanted to know what the best filler to use,
Personally I would get a plate welded in, then smooth over it. As it is too big to fill any other way really.
Posted: Thu Aug 28, 2008 10:06 am
by clarkson
ah rite cheers, but whats the bst filler for small gaps if u dont mind me asking where my vw badge is at the back of boot i took it off and there is only a small gap
Posted: Thu Aug 28, 2008 10:11 am
by Torq-Al
clarkson wrote:ah rite cheers, but whats the bst filler for small gaps if u dont mind me asking where my vw badge is at the back of boot i took it off and there is only a small gap
Bog standard filler will do it. But you will still need it sprayed, & you won't want to do a home job on it. It'll look awful if you didn't 'feather' it in etc.
Posted: Thu Aug 28, 2008 10:19 am
by Polo96CL
I would recommend plate welding the boot badge, filler is only really suitable for small jobs (such as those little slits underneath the rear lights) and smoothing out a welded recess.
by 8080
x2
You're going to have to pay for a proper respray once you fill the badge up, so I'd say you should just hold off and get the whole thing smoothed and painted by a pro in one go. Also think you should metal plate over the badge recess too. Basically get it done properly, so you only have to do it once :D
Posted: Thu Aug 28, 2008 10:21 am
by Torq-Al
Polo96CL wrote:I would recommend plate welding the boot badge, filler is only really suitable for small jobs (such as those little slits underneath the rear lights) and smoothing out a welded recess.
Yep. 'do it once, do it right'. Bite the bullet & get the whole thing done in one hit. :D
Posted: Thu Aug 28, 2008 11:10 am
by clarkson
right cheers lads, i will get it done properly then, cheers
Posted: Thu Aug 28, 2008 1:57 pm
by Torq-Al
clarkson wrote:right cheers lads, i will get it done properly then, cheers
A pleasure. :D
