vw polo foglights..
Posted: Wed Sep 03, 2008 5:45 pm
by yosin
Pickin up my polo on tuesday but the 1 of the foglights is shattered so i need to replace.
I also need to replace the driver side side lights.
Just wondering is it a straight foward job or does the bumper need to come off.
For the foglight is it just the case of taking off the grille and undo screws?
thanks
Posted: Wed Sep 03, 2008 5:48 pm
by 3LL1077
Replace side light or headlamp?
Either way you will have to remove your bumper mate, someone will be able to link you to the guide on here
And with your fogs its a simple undo the screw holding the cover on and swap the units over
Posted: Wed Sep 03, 2008 7:02 pm
by yosin
i c ic...the fogs is the worse off...i think i might go searching on the DIY but then..
however if some knows how without taking off bumper please shed some lights. thanks...Or if its like doing it on the 6n mk4?
by yosin
Side light not the headlamp btw sorry.
Posted: Wed Sep 03, 2008 7:55 pm
by 3LL1077
Posted: Wed Sep 03, 2008 8:30 pm
by Bepe
there is a way to change sidelights without taking the bumper off
Posted: Wed Sep 03, 2008 10:26 pm
by tegwin
Balderdash.....You DONT need to take the bumper off to change a sidelight bulb!!!!
You need to remove the battery if its on the nearside, or the air intake pipe if its on the offside....then its possible to get to the back of the lights....Its a fiddle....I used a mirror and head torch to do mine.....patience and its doable...
As for the foglight....if you remove the engine under-tray you can get pretty good access to the back of the fogs....I recon doing an exchange would be possible...
Posted: Fri Sep 05, 2008 12:16 am
by Tom W
tegwin wrote:Balderdash.....You DONT need to take the bumper off to change a sidelight bulb!!!!
Quite true, took me about 20 - 30 mins to do the sidelights dont know what all the fuss is about
As tegwin says i think if you jack the car right up so you can get underneath and take the undertray out you should be able to replace the foglight from there without taking the bumper off
Tom
Posted: Fri Sep 05, 2008 2:52 am
by yosin
thanks alot guyz ....just that i need to change this stuff when i pick up my gti on Tues
Posted: Fri Sep 05, 2008 7:56 am
by ticki
I need one of these also
Posted: Fri Sep 05, 2008 1:48 pm
by alexperkins
The foglight can be replaced by just removing the grille, and the three screws that hold them in - there is no need for jacking, undertray removal, or bumper removal to do this.
Posted: Fri Sep 05, 2008 2:25 pm
by yosin
ahh even better then
thought it might be possible to do this way when looking at the 1 of the side light replacement diy guides from somewhere on here.
Just cant wait till tuesday now
Posted: Fri Sep 05, 2008 2:51 pm
by ticki
Posted: Mon Sep 08, 2008 12:32 am
by yosin
By the way do you mean i can change the whole foglight housing not just the bulb?
Posted: Mon Sep 08, 2008 7:38 am
by alexperkins
Yes. If you wish to change the bulb, remove the foglight, then unclip the back and replace the bulb.
