UK-POLOS.NET - THE VW Polo Forum • HELPPPP !! oil light is flashing but no idea why !!!!!
Posted: Sat Oct 04, 2008 6:39 pm
by rick
as above however the oil level is fine and got the car scanned for codes however nothing has come up. anyon got a idea of what it could be?also its not on constanly and when it comes up theres a buzzing sound for a couple seconds.
anyone got an idea of what could be causing this???
cheers
Posted: Sat Oct 04, 2008 9:58 pm
by Bepe
hmmm, could be oil pump, as normally comes on for oil pressure meaning there isnt any so iam guessing your oil pump is foobard,
When does the oil light come on? what RPM? what speed etc?
Posted: Sat Oct 04, 2008 10:14 pm
by rick
i would say about 2000-3000 revs, not sure on the speed
Posted: Sat Oct 04, 2008 10:44 pm
by Bepe
id say its your oil pump mate, is there not any garages around near you that can check your pressure? get a compression test aswell,
Posted: Sat Oct 04, 2008 10:49 pm
by Bepe
oh and if it is your oil pump i would get it checked ASAP as oil wont be getting around the engine!
Whilst your engine is warm, leave on tick over and take the oil filler cap, can you see any oil in there being chucked about??
Could be your pressure sensor
Posted: Tue Oct 07, 2008 2:03 pm
by marcman
The oil pressure sensor switch is quite prone to going wrong. Not saying that this is your problem but it's a strong possibility.
See my post from a couple of weeks ago:
http://www.tigerstyle.co.uk/poloforum/v ... cbd02ad4b5
They are relatively cheap - £10 from VW and very easy to change.
Marc
Posted: Tue Oct 07, 2008 6:36 pm
by rick
yh got the sensor changed yesterday, hopfully solved the problem.
