REMOVE HEADLIGHTS HELP!!!
Posted: Mon Oct 13, 2008 7:09 pm
by jon44
Firstly i want to replace a headlight bulb and i just dont know how to get into it from the back. secondly the front indicator bult smashed i dont know how internally and i want to take the casing out and clear it out. HELP please
Posted: Mon Oct 13, 2008 8:01 pm
by chrisjames
Here is a useful thread..
http://www.tigerstyle.co.uk/poloforum/v ... hp?t=23920
obviously lots of it you dont need to do but use sections of it as you need.
The headlights are located just behind the black plastic cover with a big metal clip over it. The indicator lenses come out by pulling on the long plastic stick. You then twist of the bulb housing and do the same with the bulb. You will see what I mean in the pictures in that thread.
I think the car in the thread also has xenons but dont worry about that either.
Hope it helps
