jetta wheels on a polo?
Posted: Tue Oct 21, 2008 1:15 pm
i've been offered a set of 15 wheels off ajetta and as far as i know they'll fit as both are 4 x 100,but i just wanted to make sure.if anyone knows for definate i'd be greatful
Probably the Worlds greatest Polo resource
https://uk-polos.net/
Nope, there's 4x100, adn 4x130 used by VW, also 5x100, 5x130 and 5x112 is/was used, some of them are rare, but should be taken into mind when looking for other VW wheels, just get them 4x100, or use adapters to fit themTim_GTi wrote:If they're 4X100 then they should be fine. Pretty sure VW all use the same bore when it comes to the same stud numbers.
Whoopsalexperkins wrote:Hes reffering to the center bore Jarno being 57.1mm not the stud pattern
