How to remove rear door panel on a Polo 9n with 5 doors ?
Posted: Sun Mar 07, 2004 11:33 am
by Doudou
Hi, i've got a polo 9n with 5 door, and i have a problem to remove the rear door panel to install some sound.
i can see that there's a lot of clips, and that the handle is screwed, but i don't know how t remove the crank !!!!. So i hope that you have some idea to help me !! :roll:
Posted: Sun Mar 07, 2004 12:27 pm
by Scorpio1
Where the door handle is pop off the black cover with a small flat screwdriver and there should be torx screws behind it.
I should imagine the window winder pops off or has a little cover with a screw/bolt behind it.
I'm not too sure about the 5 door sorry :(
But make sure you have extra clips as they break easily!
thanks for answering me
Posted: Sun Mar 07, 2004 12:31 pm
by Doudou
thans i will trie :D
