mk5 2000 polo front bumber removal!!
Posted: Wed Mar 10, 2004 11:33 am
by jon_poloV
i want to remove the front bumber so that it is easier to change the splitter over, my car is lowerd and it a nightmere getting your head under the front to uncliff the splitter and change it, i think to be honest it would be a whole lot easier to do it with the bumper off, is it easy?
any advise hints or tips would be very much apriciated .
cheers
Posted: Wed Mar 17, 2004 7:01 pm
by polo2k
4 screws along the top
5 or six under the arches incl the vertical one
one behind each fog light cover
and then 4 clips underneath that you have to pull the centre out of
then the 2 hidden ones under the indicator
-to remove the indicators look for the piece of white plastic shaped like this ( =0= ) with a phillips shaped head in the "O" turn this 1/4 a turn and then lift then pull the inticator foreward to reveal the hidden screw on each side
i beleve you need
T35
T40
Phillips screwdriver
pair of pliers to raise the indicator release
and somthing to mutilate the lower clips with
removing bumper
Posted: Fri Aug 27, 2004 1:10 am
by Adam
hello
gonna remove the front bumper tomorrow, need some help. just wondered if you could give me anymore info, cheers
