GTI Aftermarket speaker adaptor plate
Posted: Thu Dec 25, 2008 1:10 pm
by chris meardon
Hey guys, i am putting some raimbow comps as well as other sound system stuff in my polo, just checking that this is the right adaptor part to enable the speakers to go in?
http://caraudiosecurity.com/shop/produc ... /2003.html
cheers guys
Re: GTI Aftermarket speaker adaptor plate
Posted: Fri Dec 26, 2008 11:27 am
by alexperkins
Dont even bother with it. Just cut the two little plastic pins on the current speaker plate off then you can use that one. Plus, the replacements are cheapo plastic that the screws pull out of very easily!
Posted: Mon Dec 29, 2008 7:51 pm
by Tim_GTi
What's the depth of the speakers your getting? Because this is an issue with better spec speakers on the GTi.
Posted: Tue Dec 30, 2008 12:35 am
by chris meardon
They are these monstors
http://caraudiosecurity.com/shop/produc ... /3985.html
will it be an issue?
Posted: Tue Dec 30, 2008 8:01 am
by Tim_GTi
hhhhmm.. you should be ok. Mine are 59mm and fit, where as those are 65mm.. I can't remember how much space I had back there, but they should be alright.
