Hey... Where's the boot light guide?
Babe RuthLess
Post by Babe RuthLess »
Hi there...
Sorry to press the subject like this but... I would really like to install that boot light mod listed in the 9N guide, but I don't have the courage to try it without a proper walk-through guide!
Has anyone tried it? Do I need new wiring?
Cheers,
Scorpio1
Post by Scorpio1 »
I can't really help but I found an old post here
I think memm or mole could help?
memm
Post by memm »
Here's a google translation
http://translate.google.com/translate?h ... 8%26sa%3DG
If I have time I will translate it properly, but I am quite busy at the moment..
First you need 12V, If you have the PowerOutlet in the boot you might get it from there.. The courtesy light is not the "closest" choice, but that's where my boot light gets the 12V from.
On the opposite side of the bootlight (left side of the boot) there are 3 plugs hidden. Connect a cable at the 5th Pin of the top plug (there should be a brown/black cable)
You only need these 2 cable, the 12V one and the one from Pin5 (boot open/closed), connect them to the boot-light
