Polo GTI window experts needed!!!
Posted: Sat Jan 17, 2009 7:30 pm
by chris meardon
Ok i no there are numerous posts on the window problem that gtis have but i really cant find my problem in those posts.
When i got the car the drivers window didnt work, and on the drivers side switch if you pushed the button for the passenger door enough it would go down, and it still gos up.
So heres a list of what works and what doesnt
Drivers side switch - drivers side window - up = NOT WORKING
Drivers side switch - drivers side window - down = NOT WORKING
Drivers side switch - Passenger window - up = WORKING
Drivers side switch - Passenger window - Down = Not working
Passenger switch - passenger window - up and down = working
Can anyone shed some light?
thanks
Re: Polo GTI window experts needed!!!
Posted: Sat Jan 17, 2009 11:53 pm
by chrischap2003
Window regulators are knackered mate. Common fault on Polo and alot of other VW's to be honest lol My Golf Cabby mk3 has the same issue and my Polo is on its way to this.
I think (dont quote me though) they are around £70 :-s
Posted: Sun Jan 18, 2009 8:20 am
by alexperkins
Cant be the regs as the passenger side window is working on the passenger switch. Check the switch from the passenger side in the drivers side and see if that makes a difference. Drivers door could be the switch or the reg, but you can use a reg from any 3 door or 5 door MK5 polo with electric windows as they all have the same ones - its just a different window guide!
Posted: Tue Jan 20, 2009 2:41 pm
by chris meardon
Ok guys cheers for the replys, i need to change the speakers in the car so when i have the door apart i will have a look around, can you advise me as to where the regs are?
Posted: Wed Jan 21, 2009 9:57 am
by neilw
Check for broken wires in the rubber boot between the door and car. Similar thing happened to mine and found there was a split earth cable in there. Does the central locking button work?
Posted: Sat Jan 24, 2009 11:36 am
by chris meardon
yes centeral locking works mate
Posted: Sun Jan 25, 2009 7:02 pm
by tegwin
Had a similar issue....
The switches had got wet at some point and gave similar symptoms... try replacing the switches... its easy and doesn't cost too much!
Posted: Wed Feb 18, 2009 7:21 pm
by charliec125
hey i no its a late reply but i had the exact same problem,
got the switches from vw £14 each now everything works perfectly :) try that before buying motors and stuff,im glad i didnt waste money on a mech i didnt need.:)
Posted: Wed Feb 18, 2009 8:52 pm
by chris meardon
thanks mate i will get down VW asap, its so annoying
