Steam Cleaner
Detailing & Bodywork
des_pd_ tdi
Steam Cleaner
Post by des_pd_ tdi »
Bought myself a mini steam cleaner at the ideal home exhibition last Friday and this little beauty works wonders on alloy wheels and on the calipers, brings them up a treat.
Cost £29.99 = :D
Goz1
Post by Goz1 »
Sounds good! Is there any info on the net about it? Cheers Cora :)
polo2k
Post by polo2k »
little warning on steem cleaners:
the big ones will puish out over 5000psi at the nosske at over 100oC so they can quite easilly strip paint and melt rubber components like windscreen rubbers
des_pd_ tdi
It's not that powerful.
I wouldn't use the thing on the window rubbers I bought it purely for the wheels and general household use, the sad DIY geek that I am.
I'll see if the company have a website.
polo2k
Post by polo2k »
oh yeah i understand i was just warning peeps with access to the big diesel powered jobbers
des_pd_ tdi
If you do buy a steam cleaner test an area first and gently warm the area first otherwise you could get into trouble.
