VAG-Report... Can anyone help?
Posted: Wed Feb 11, 2009 10:15 pm
by tegwin
Driving home tonight... as always stuck behind slow moving traffic... The Engine check light came on... shortly followed by the emissions light..
The VAG-COM report looks like this:
VAG-COM Version: Release 409.1-US
Chassis Type: 6N - VW Polo
Scan: 01,02,03,08,15,17,19,25,35,41,45,46,55
Address 01: Engine
Controller: 036 906 033 D
Component: 1.6l/4V SIMOS3 00HS3512
Coding: 00031
Shop #: WSC 00788
WVWZZZ6NZ1Y350568 VWZ1Z0A1574895
4 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17584 - Bank1: O2S (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 6X0 907 379 C
Component: ABS/EDS 30 IE CAN V004
Coding: 05603
Shop #: WSC 00788
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
16-10 - Signal Outside Specifications - Intermittent
Address 08: Auto HVAC
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 04001
Shop #: WSC 00788
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 6N0 920 904 K
Component: KOMBIINSTRUMENT BOO V13
Coding: 00444
Shop #: WSC 00439
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN
Coding: 00022
Shop #: WSC 00000
Address 25: Immobilizer
Controller: 6X0 953 257
Component: IMMO 0008
Coding: 00001
Shop #: WSC 00000
Address 45: Inter. Monitor
Controller: 6N0 951 171 C
Component: Innenraumueberw. 0003
Address 46: Central Conv.
Controller: 6N0 959 799 B
Component: 8U Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00788
Address 55: Xenon Range
Controller: 6N0 941 273
Component: Leuchtweiteregelung 0001
Coding: 00002
Shop #: WSC 00788
End --------------------------------------------------------------------------------------------------
Anyone have any idea what the engine codes relate to and why they have come up?
(I replaced a faulty water temp probe a few months ago.. so I assume that error log was from then, rather than a recent one)
I have cleared them.. but I imagine they will return...
And...anyone care to hazard a guess what any of the others relate to?
Really worried about the engine... I am about to do a cambelt...and might as well do anything else thats needed whilst its appart...
Re: VAG-Report... Can anyone help?
Posted: Thu Feb 12, 2009 4:36 pm
by Bepe
looks like BOTH lambda sensors are kaput? B1 is the first one being Bank1 and a temperature sensor, and probably an airflow meter too
by Bepe
saying that though, your CAT could be on its way...
Posted: Thu Feb 12, 2009 5:33 pm
by tegwin
There were no unusal readings at the last MOT to suggest a failing CAT....
Its weird.. I cleared the codes last night... Drove to work this morning and then did the same stop start drive home... and the engine check light came on at exactly the same time as before..comming up a steepish hill in 1st/2nd in traffic...
I ran VAG-COm again when I got back and the only thing in the engine report this time was a faulty engine temp sensor.... which I only replaced a few months ago..FFS...
Im wondering if all these faults are caused by the same thing... a dodgy cable/connector somewhere....
Posted: Fri Feb 13, 2009 9:37 pm
by alexperkins
The air con motor is nothing to worry about (HVAC). It only needs to be replaced when the air con stops directing air properly.
Temp sensor may well be a dodgy connection - have a look to make sure the connections are clean. Was it a gen VW sensor?
As for the lambdas, it sounds like a possible short circuit. Have a look to make sure the wiring is intact and that nothing is touching or split.
Posted: Sat Feb 14, 2009 1:02 am
by tegwin
No, the temp sensor was a replacement part from the local motor factors....its the right colour and part number..... I guess the official VW one might be slightly different.......possilbly.... its not showing any errors on the dashboard temp guage though which the old dodgy one did....
...As for damaged lambda wiring... I have to do the cambelt next weekend so I will have a good shufty around under the car when the undertray is off and see whats what.,....inspect everything in the hope that I get lucky and find the fualt...
