idle issue
Posted: Thu Mar 18, 2004 12:17 am
by kevin
hi there have just bought a 1983 1.1 polo coupe, in mint condition but there are a few little niggles that need sorting,needs a wheel bearing,easily sorted,but there is a problem with the carb it will not tick over changed gasket between carb and manifold sealed it and no difference, the idle adjustment screw does nothing,drives fine but stalls when comming to a halt its a HB engine . the guy i bought it off told me that he had it checked by a carb specialist and was told that the carb needs replaceing badly worn. as i have never had a polo before looking for a bit of advice on what to do next.
regards kevin
Posted: Thu Mar 18, 2004 4:14 pm
by serge pot
check your points they should be 0.45mm in open position
Posted: Thu Mar 18, 2004 5:27 pm
by kevin
serge pot wrote:check your points they should be 0.45mm in open position
have done that thanks. any more ideas,does someone know where i can get a carb replacement ,as german and swedish say the carb for this model is discontinued.
regards kevin
Posted: Thu Mar 18, 2004 6:34 pm
by hardhitter
It could be the idle cut off valve not working correctly. You could probably get a second hand carb from a scrappy and try that. It definately seems like a carb problem to me, quite common too. I'm not sure if it's a weber or pierburg, as the latter seemed to give more problems.
HTH
Posted: Thu Mar 18, 2004 7:15 pm
by kevin
hardhitter wrote:It could be the idle cut off valve not working correctly. You could probably get a second hand carb from a scrappy and try that. It definately seems like a carb problem to me, quite common too. I'm not sure if it's a weber or pierburg, as the latter seemed to give more problems.
HTH
hi m8 thanks for the reply, its the early model before the idle valve ,SOLEX carb with manual choke.
regards kevin
sounds like
Posted: Thu Mar 18, 2004 9:59 pm
by madmatt
air bypass vavle (cut off valve) replace that should be ok i hope
Posted: Mon Mar 29, 2004 10:30 pm
by kevin
hi guys just a quick update got the car to tick over at last but thats when the carb mixture is really rich, as soon as i weaken the mixture she stalls,the tick over adjustment scew seems to do nothing at all, I have taken it out for a run and all seems ok.but i can't see it passing a mot when running this rich.any ideas.
regards kevin
Posted: Wed Mar 31, 2004 8:37 pm
by Phoenix
use this as a good excuse to get some twin webers :lol:
Posted: Wed Mar 31, 2004 10:58 pm
by kevin
Phoenix wrote:use this as a good excuse to get some twin webers :lol:
yes i think a new carb will be on the cards,i hope to take it for its MOT next week so we will see what happens! have been given a price of £150 for a new webber from e.c.p, is that good? dont want to spend a fortune on it as its not my daily driver,its mainly for the missus.
regards kevin
