Page 1 of 2
2001 polo gti speedo and fuel guage probs......
Posted: Fri Mar 13, 2009 8:37 pm
by dave-g
hiya guys....(again lol)
just been out for a drive in my polo, as i've just got it back from having the gearbox done, but for some reason, outta the blue the speedo went dead, and the fuel guage decided to continually go up and down? any ideas what could of happened? its had a new speedo sensor, and one new injector fitted, but othe rthan that i don't have a clue what would be relevant?
any help would be much appreciated, i just want a day of pain free motoring!!!
cheers guys
Re: 2001 polo gti speedo and fuel guage probs......
Posted: Fri Mar 13, 2009 10:48 pm
by Tim_GTi
Have you checked all the relevant fuses?
Posted: Sat Mar 14, 2009 7:48 am
by alexperkins
It sounds like they took a ground strap off somewhere, which is making the dials go nuts.
Posted: Sat Mar 14, 2009 5:19 pm
by dave-g
i attempted to look at the fuses but don't really have a clue where to start the symbols mean nothing to me....... any numbers you could suggest anybody??
wher abouts are the ground straps located to just so i can check, the fuel guage is still constantly goin up and down :?
thanks for the replies and help guys, i appreciate it!!
Posted: Sat Mar 14, 2009 5:28 pm
by Bepe
iam pretty sure there is an earth strap onto the gear box, maybe that isnt on properly or needs a good wire brush for better contact
Posted: Sun Mar 15, 2009 4:00 pm
by dave-g
right guys, ive checked EVERY fuse in the fuse box, and on the battery cae thingy, and wire brushed the gearbox earth strap so thats clean as its gunna get, any idea where theres any other earth straps on the engine anywher or any other wires that may be promising??
cheers guys!!
Posted: Sun Mar 15, 2009 4:37 pm
by alexperkins
Check your negative battery lead is connected to the chassis properly as they have to have the battery out normally to do the box.
Posted: Sun Mar 15, 2009 7:22 pm
by dave-g
yeah i thought the same earlier, the battery was out, and the neg lead was tugged around a bit, so may have done something there i gues.i disconnected the bit from the gearbox and cleaned the connector up, and then reattached it all. it was weird though, was just driving along and suddenly the fuel guage started moving up and down (tends to a lot around corners) and the speedo sits on 0mph. when i turn the ignition on though the speedo needle twitches a little, as if it does have life still, and the rev counter and temp guage still work.........its soo frustrating why it did it!! :oops:
again thanks for taking the time with this guys, i really appreciate it!!
Posted: Mon Mar 16, 2009 10:55 am
by sorted
Hi Mate,
It will be the speedo drive. Its screwed into the gearbox at the front - and then a connector plugs onto it - it then gives a reading to the speedo. This also makes the petrol gauge do weird things - done the same on mine.
I managed to snap the pin inside me after a long mway drive, got one from a scrappy (£10) or £30 from the dealer. Two secs to fix - just a deep socket and unscrew the sensor and fit the new one (if it needs one)
Neil
Posted: Mon Mar 16, 2009 1:08 pm
by dave-g
i took the sender apart yesterday during the day, but it was replaced in january time, just wondering if when the bloke fitted it that he yanked it or damaged it, spose its better spendin 30 to try than 300 if its not lol.
did your fuel guage constantly go up and down, and move randomly by itself? and the speedo sit on 0mph?
thanks for your help mate :wink:
Posted: Mon Mar 16, 2009 3:26 pm
by sorted
Yeah, it sat at 0 and twitched. The fuel gauge had a mind of its own - full then empty, then level then not LOL... all the polos have the same sender - so maybe get down a scrappy - or try a mate with a polo's sender!
Neil
Posted: Mon Mar 16, 2009 4:55 pm
by dave-g
yeh thats a good point, my mates got a gti so might try his tomorrow and see what happens! it sounds like the same problem that you had so worth a shot!! :D
thanks mate!
Posted: Mon Mar 16, 2009 8:02 pm
by shantybeater
these are exactly the symptoms mine started doing, hopefully this thread has saved me alot of time & money, cheers 'sorted'
Posted: Tue Mar 17, 2009 12:22 am
by dave-g
haven't managed to check mine as of yet, but on another negative note had four new tyres fitted and they've ruined all of my wheels!!! ripped the laquer of my rh cup blacks, and scratched all the lip up too. damnit!!!!
they're refurbing them as i write this lol. i hate amateur tyre blokes :cry: its poop.
spoke to another mechanic, just cos he was at work who reckoned that the gear that drives the speedo is broken, which fingers crossed it isnt!!! i'm hoping/praying on everything its just this switch!!!!! gunna try a scrappy tomorrow, just to check it out :D
Posted: Tue Mar 17, 2009 7:53 pm
by Tigz
I have exactly the same problem!
But thats because I used the gearbox from a 1.4 so the plugs for the speedo and the reverse light switch are different.
Fuel gauge, goes down when I turn right or put my foot down and goes up when I turn left or brake! lol
