Hi everyone.
I did a search on this forum and couldn't find any guides on how to change the front indicator bulb on my R reg polo. The manual has instructions to change all the other lights but for the front indicators it says, "See VW dealer".
Is it going to be a big job to change this? How easy is it to do it yourself?
Many thanks.
Changing Front Indicator Bulb
Re: Changing Front Indicator Bulb
It is muchly easy. Basically, remove the back casing, remove the current bulb, and insert the new one. Just fiddle around if you are having trouble, there isn't anything you can break lol. Trust me, jus tup the bonnet and pull and tug etc until you've done it. Simple to do. (Man that sounds so unhelpful, sorry. )
