coilover help
Posted: Thu Apr 16, 2009 6:00 pm
by SimonCorrigan
hi after some help. had a god awful day replacing the console bushes - what a nightmare to get out. got them done and moving on to the coilover. got some coilover from ta technics and not sure if the correct ones have been sent. i have a 2003 polo 1.9 tdi (100bhp) and this is what i got.
http://i564.photobucket.com/albums/ss86 ... 009278.jpg
http://i564.photobucket.com/albums/ss86 ... 009279.jpg
got some new top mounts and top mount bearing trouble is with the aluminium top on the coilovers there is not enough thread on the top of the strut to put the nut on. taking off the aluminium top off and the tops mount etc fit but the spring doesnt seem to sit right.
with alumininum cone - http://i564.photobucket.com/albums/ss86 ... 009280.jpg
without - http://i564.photobucket.com/albums/ss86 ... 009281.jpg
i can get he aluminium cone machined so it fit around the shaft of the strut but not not sure if that is the ideal way forward. or am i just being thick and missed something obvious.
any help, comments, suggestion would be great as i need to get this done by saturday!!
cheers,
si
Re: coilover help
Posted: Thu Apr 16, 2009 9:45 pm
by Kuru14
Its not you i had the exact same problem, These coilovers really are budget. I fitted mine to the car without the aluminium caps after being reassured by a friend of my dad whos a mechanics that it wont slip, but dont quote me on that :shock:
im trying to look into machining the cone myself so itl fit but let me know how u get on with this
Re: coilover help
Posted: Thu Apr 16, 2009 11:21 pm
by dsw88
you'vee got the same coilovers as me, i had to file alway round the inside of the cone for it to slide up and down the steel pole with the thread on the end, didnt take too long to do as its a soft aluminium but i got mine to fit perfect, no problems at all.
Re: coilover help
Posted: Fri Apr 17, 2009 7:21 pm
by SimonCorrigan
right got these machined and now a perfect fit. nice and low now with about 30mm ride height!
Re: coilover help
Posted: Fri Apr 17, 2009 7:40 pm
by Kuru14
How far down did u guys machine/file it away by?
Re: coilover help
Posted: Fri Apr 17, 2009 9:43 pm
by dsw88
i did it so it would slide down the steel shaft but with no gap, the steel shaft only just fits through it
Re: coilover help
Posted: Sat Apr 18, 2009 7:30 pm
by SimonCorrigan
had it machined out to 22mm so fits on the shaft. a local guy charged £5 for doing it and it took about 10mins.
Re: coilover help
Posted: Sat Apr 18, 2009 8:30 pm
by Kuru14
thanks for that will look into getting that done v.soon
