Page 1 of 2
20mm spacers
Posted: Thu May 07, 2009 4:29 pm
by ticki
hey guys
If have 20mm spacers on my standard BBS's, will i nee my arch's rolled?
thanks
Re: 20mm spacers
Posted: Thu May 07, 2009 8:12 pm
by Tim_GTi
Nope, I think you'll be just fine. if your riding a really low stance though I'd recommend 15mm.
Re: 20mm spacers
Posted: Thu May 07, 2009 10:42 pm
by ticki
Here is some pic's for maybe a better idea of my clearance etc. Im runnin 195/45 R15 Yokohama S drives. (these are quite wide 195's imo)
Despite being on FK Coilovers, Im not very low at all you can say.
Re: 20mm spacers
Posted: Fri May 08, 2009 10:39 am
by ticki
after that info, will i need my arch's rolled for 20mm spacers?
Re: 20mm spacers
Posted: Fri May 08, 2009 12:07 pm
by Tim_GTi
Right, judging by my calculations your wheels will be sat pretty much exactly the same as mine.
Here's mine:
I only get scrubbing if I'm cornering really hard and hit a bump in the road. In otherwords it's not an issue at this height at all. I was about 10mm lower and that did scrub, but my current stance is lower than you are now, so that irrelevant.
So given that, I'd say you'd be fine!
However.... I have 165/50 tyres, and you have 195/45s. I'm not saying this would make any difference (as your wheels are slightly wider than mine) but it means my calculations can't be 100%.
Hope this helps mate
Re: 20mm spacers
Posted: Fri May 08, 2009 3:22 pm
by ticki
that does mate, alot. its the stretch that helps im guessing.
195's im worried will cause impact not just rubbing with the arch, if i go over a bump.
anyway im looking at these 20mm hub adapters type, they are steel, which concerns me but they are cheap.
any comments
http://www.lkperformancestyling.co.uk/p ... roduct=608
Re: 20mm spacers
Posted: Fri May 08, 2009 5:40 pm
by Tim_GTi
well thats the thing., mine are only 6j wide, so theres no stretch really. they do add a nice slant to the sidewall tho.
have you considered 15mm to be safe?
Re: 20mm spacers
Posted: Fri May 08, 2009 6:18 pm
by ticki
15mm wont fit over the spigot on mine
i actually have 2 sets of 15mm spacers that my bro gave me a while back.
they fit perfectly on the fronts but fail on the rears
Re: 20mm spacers
Posted: Fri May 08, 2009 8:52 pm
by Tim_GTi
That sucks. I thought spacers normally accomodate space for the spigot?
Re: 20mm spacers
Posted: Sat May 09, 2009 10:24 am
by ticki
VW decided to have longer spigots on the rear hubs for some reason
Re: 20mm spacers
Posted: Sun May 10, 2009 4:43 pm
by ticki
so im going for 15mm in the front and 20mm at the back
15mm on the front? do you think its too much? win or fail?
Re: 20mm spacers
Posted: Mon May 11, 2009 3:04 pm
by Tim_GTi
i think that'll be nice! although i'm not a personal fan of staggered stances (for understeering reasons) it's still a win for me.
Re: 20mm spacers
Posted: Mon May 11, 2009 5:46 pm
by ticki
oh dear, i never thought of that.
all ive ever done on my polo is to try and dial out the understeer.
Coilovers
Rear Anti Roll Bar
-1ยบ camber on front wheels
well on Sunday I tried just one spacer on the front just to have a look. I didnt drive it.
with spacer on
with spacer on
Passenger side with no spacer
Re: 20mm spacers
Posted: Mon May 11, 2009 10:50 pm
by Tim_GTi
They do look good. It depends what's more important to you though I suppose. My car is more for looks, but am still not a fan of the whole staggered thing as it literally (although subtly) cripples the handling.
Re: 20mm spacers
Posted: Mon May 11, 2009 10:54 pm
by ticki
thanks for the heads up mate.
I have to try it out and see, what happens.
Looking at my front wheel there. Do you think im gonna get scrubbage?
