Reverse Light goes out when Clutch is lifted
Posted: Tue Jun 09, 2009 5:50 pm
by MGrove03
I drive a Polo 9n3 and basically whenever i'm reversing the reverse light will come on (clutch pressed to the ground), then whenever I lift the clutch and start moving it will go out. The light then comes back on once I stop moving and the clutch is again pressed to the ground.
Any help appreciated
Re: Reverse Light goes out when Clutch is lifted
Posted: Mon Sep 10, 2012 12:19 pm
by samways-polo
i know this is bring up a really old thread, but does anybody have a solution to this ?
cheers
Posted: Sun Sep 23, 2012 12:35 pm
by fonzooorooo
could be the first signs of a broken wire at the plug on the gearbox - the vibration from the movement breaking the connection. Just a thought - it's an item that's prone to failure.
