shortended droplinks? what and why?
Posted: Tue Jun 23, 2009 5:46 pm
by stu768
can someone explain this to me i have a 9n going to be lowered on ap coilovers tomorrow 205 40 17 am i going to be able to wind them down low enough for this size wheel or do i need droplinks ( not that i know what they are..)
Re: shortended droplinks? what and why?
Posted: Tue Jun 23, 2009 6:29 pm
by pip_polo
that are what connect your ARB (Anti-roll Bar) to the car.
the ARM runs basicly under the engine area to 'hold' the car together for better handling.
Having shortened drop links then moves the ARB higher and futher away from the drive shaft.
When lowering the drive shaft will come into contact with the ARB as the ARB is now lower, so to go over 50mm lower shortened droplinks will stop and rubbing between the ARB and drive shaft. (in theory as mine doesn't
I've hurd a few of the mk7 (mainly GTi lads) go for mondeo drop links. but i just ordered shortened droplinks when i bought my coilies and got them thrown in mega cheap.
hope thats correct/helpful.
Posted: Tue Jun 23, 2009 6:32 pm
by stu768
so its just on the front yeh? hmmm think ill see how it goes :/ where can i order some from if i need them?
Posted: Tue Jun 23, 2009 6:40 pm
by chewy
Ebay got for mk3 mondeo ones
You can get them for about £15 for a pair.
I am running coilovers and I have not changed the drop links and don't have a problem, it all depends how low you go.
I don't suppose you know the off set of your wheels?
Posted: Tue Jun 23, 2009 6:49 pm
by pip_polo
the offset will be on the wheels it'll be something like et34 for example.
my new wheels are et38.. far too tucked inside the arch
Posted: Tue Jun 23, 2009 6:51 pm
by chewy
pip_polo wrote:the offset will be on the wheels it'll be something like et34 for example.
What are you running now pip?
5mm spacers ftw
Posted: Tue Jun 23, 2009 9:09 pm
by pip_polo
chewy wrote:pip_polo wrote:the offset will be on the wheels it'll be something like et34 for example.
5mm spacers ftw
5mm pfft. 10mm when i can find some.
i'll get pictures up as i'm off to inters at weekend.
we allways end up spammin other peoples threads by going completly off topic
Posted: Fri Jun 26, 2009 2:22 pm
by stu768
ive got tt comps, wondering what tyres i should get??
and could someone link me to some droplinks so i can put it as low as possible with minimal rubbing?
Posted: Sun Jun 28, 2009 11:01 am
by stu768
want to go lower can someone link me to what droplinks i should buy?
Posted: Sun Jun 28, 2009 11:28 am
by chewy
http://cgi.ebay.co.uk/FORD-MONDEO-MK3-F ... 7C294%3A50
Have a look at that mate. I am running tt comps and have not changed my drop links.
The only noise I get is the tyre rubbing on the arch liner over large pot holes
I have them wrapped in 205/40/17 toyo proxes
Posted: Sun Jun 28, 2009 11:47 am
by stu768
how low have u got it though?
Posted: Sun Jun 28, 2009 1:32 pm
by chewy
Its sitting about 2.5cm from the top of the alloys, front and back
Posted: Thu Jul 02, 2009 1:57 am
by stu768
would i hear this noise if the arb etc were rubbing? ive lowered my ap coilovers all the way down on the back and its sat more aless on the front tyres of my tt comps 205 40, no noises or anything?
