Emissions nightmare continues!
Posted: Sat Jul 04, 2009 6:34 pm
Hi everyone.
A few months ago I posted about my emissions nightmare around the MOT. Well since the light was coming on so often I took it to a really good diagnostics place I know for and they replaced my cat converter as it was hollow. The emissions light came on again with a week and the ECU kicked into limp mode as it was a coil again. I replaced two coils so that each coil is now an NGK factory fitted one. Now the light has re-appeared after a month (with no difference in the performance). The fault code that is coming up at the moment is:
17550/P1142/004418 - Load Calculation Cross Check: Lower Limit Exceeded
I typed it in on Rosstech-Wiki which retrieved:
Possible Causes
Mass Air Flow Sensors (G70) faulty
Intake Air System faulty/leaking (false Air)
Throttle Pedal faulty
Throttle Body dirty/faulty
Possible Solutions
Check Mass Air Flow Sensors (G70)
Check Intake Air System
Check Throttle Pedal
Check Throttle Pedal Position Sensor (G79)
Check Throttle Pedal Position Sensor 2 (G185)
Check Throttle Body
Check Angle Sensor 1 for Throttle Actuator (G187)
Check Angle Sensor 2 for Throttle Actuator (G188)
Check Engine Control Unit
Would it be worth me garaging the car for them to check the relevant areas or does anyone have any hunches as to what it could be? Also I am not sure whether the emissions are rectified since the replacement of the Cat converter. But it clearly needed a change as it was hollow.
The vehicle in question is a 1.4 petrol Polo 9n 52 plate with BBy engine code.
Many thanks.
Possible Causes
Possible Solutions
Check Throttle Body
Many thanks.
