What 1.8t
Posted: Fri Jul 10, 2009 1:12 pm
Need some advice on what 1.8t to use and what gearbox???
Frome a passat 2003?
Probably the Worlds greatest Polo resource
https://uk-polos.net/
You can get a passat engien that is horizontal mounted.... The car is a 6n2Torq-Al wrote:You'd stuggle with a Passat engine, as its longitudenally mounted in the car. A golf engine is transverse & what u'd want. Too many brackets, hoses, manifold etc to find if you got a Passat engine.
yep, mark 3 ibiza cuprarevolutionrock wrote:There is a seat whit a 1.8t? am I right? Any other models?
And the Leon. (180bhp). BAM engine is the audi TT engine. (225bhp)Tim_GTi wrote:yep, mark 3 ibiza cuprarevolutionrock wrote:There is a seat whit a 1.8t? am I right? Any other models?
Just found some info that will make your life easy! Use an Ibiza Cupra gearbox & driveshafts for ease of transplant.revolutionrock wrote:How have they done whit the drive shafts? make new?i think the easiest way would be to make new ones?
How wide is the axle track on a ibiza?Torq-Al wrote:Just found some info that will make your life easy! Use an Ibiza Cupra gearbox & driveshafts for ease of transplant.revolutionrock wrote:How have they done whit the drive shafts? make new?i think the easiest way would be to make new ones?![]()
Then you'll need to make custom engine mounts to enable you to put your choice of 1.8T in.
Apparently if you go on club-polo & search for ash's polo you'll find some useful info.
Should be same as a Polo, think it's same floorpan, or very close!?revolutionrock wrote:How wide is the axle track on a ibiza?Torq-Al wrote:Just found some info that will make your life easy! Use an Ibiza Cupra gearbox & driveshafts for ease of transplant.revolutionrock wrote:How have they done whit the drive shafts? make new?i think the easiest way would be to make new ones?![]()
(Im gona googel it)
