Wee problem! wheres the polo mk 4 experts?
Posted: Tue Sep 22, 2009 2:40 pm
by kyle_mk3
temp light keeps flashing up on dash, have replaced the sensor under the bonnet after a few reccomendations and still no joy have also tried disconnecting the switch at the expansion/water tank, temp isnt going past half way which im told is completely normal. does anyone have any ideas what could be causing this? if so can they drop me a email at the address below n let me know asap please.
cheers kyle
[email protected])
Re: Wee problem! wheres the polo mk 4 experts?
Posted: Tue Sep 22, 2009 6:15 pm
by kyle_mk3
ok after taking it to an audi/VW garage its now went off....was on when i got there but when i stopped the engine and went in n got the mechanic who revved the arse out of it, it wouldnt go on again.....even after takin it 4 a long drive. is it a case of reset of the ECU? if so can it be manually done?
Posted: Tue Sep 22, 2009 9:38 pm
by NOZ
Just disconnect the battery for an hour, which resets the ECU.
Posted: Wed Sep 30, 2009 1:31 pm
by Jay77
Hi Kyle
I have the same problem as you, did you try what Noz advised you if so did it work and did you encounter any other problem?
Posted: Mon Oct 12, 2009 8:51 pm
by kyle_mk3
it didnt work, the light went off for no more than a day then back to flashin up...any luck on yours?
