climatic blowing hot air
Posted: Fri Oct 09, 2009 9:06 pm
by biggy
Hi there,
my polo 9n sport climatic heaters have recently started blowing only hot air, even when I set it to cold and with ac on it still doesnt make a difference, does anyone know what could be wrong?
cheers
Re: climatic blowing hot air
Posted: Sat Oct 10, 2009 1:15 pm
by KO
Hi Biggy
My Polo has been doing this for a while now. it seems the temperature flap maybe stuck. i'm trying to find the part and guide on how to change. So if anyone on here has fixed the same issue, please let us both know how you did it.
KO
Posted: Fri Oct 16, 2009 2:20 pm
by biggy
Hi there,
when I turn the car off and then turn on the cold temp before starting the car then it seems to blow out cold air until I turn the temp back to warm, then it gets stuck on warm air again, you could be right, but is it an easy repair?
Posted: Sat Oct 17, 2009 1:33 am
by biggy
KO wrote:Hi Biggy
KO
you were right, it is the temp flap that is at fault according to vag-com. Now just to find out how to change it, if I find the answer I will update you. thanks
Posted: Wed Oct 21, 2009 9:34 pm
by biggy
now sorted by replacing the temp flap motor.
