6n2 interior for 6n?
Posted: Fri Nov 06, 2009 3:20 pm
by VWking
Can you put a 6n2 interior into a 6n? I know you can use the dash but that requires a lot of work.
Can the front and rear seats, including the door cards be stripped from a 6n2 and put into a 6n?
Re: 6n2 interior for 6n?
Posted: Fri Nov 06, 2009 6:10 pm
by randomage
Seats should be a simple enough swap, all you'd need to do (if anything) is swap subframes over. Doorcards is a tricky one. If you can adapt the doorhandles and any electric bits (mirrors) then it would just be a case of seeing if the doors are the same shape.
Posted: Sat Nov 07, 2009 11:41 am
by VWking
Oh ok, that seems simple enough! I don't think I will bother with the door cards but just the seats! Thanks :)
Posted: Wed Nov 11, 2009 2:49 pm
by Dan 6N
Yep, seats are a straight swap, I'm selling some if you're interested..
Posted: Wed Nov 11, 2009 3:06 pm
by VWking
If only a couple of days ago! I managed to get my hands on some! Thanks anyway :D
Posted: Mon Nov 30, 2009 9:57 pm
by tinsley
i'm selling a 6n2 dash if you intrested and the door cards dont fit sraight in door handles need to be moved
Posted: Tue Dec 01, 2009 12:58 pm
by Polo96CL
Door cards require relocation of the handle, a few bits for the clips and modification to the cables to pull the catches :)
