brakes
Posted: Thu Nov 12, 2009 9:45 pm
by g__humm
first thing do tt 312mm brakes fit on a gt and under the 16 inch for front
and do the rear brakes off an octavia vrs fit ??
Re: brakes
Posted: Sun Nov 15, 2009 3:43 pm
by pip_polo
you need the mk1 octy 2wd brakes. as i think the 4wd ones don't fit. and yes..
you've opened 2 threads too :roll:
Re: brakes
Posted: Sun Nov 15, 2009 4:10 pm
by g__humm
yer need to know like fast lol
Re: brakes
Posted: Fri Nov 20, 2009 12:21 am
by GR33NIE
So TT 212mm do fit!? Front and Back??
Re: brakes
Posted: Fri Nov 20, 2009 5:39 pm
by pip_polo
yes the 312mm do fit. and the back also fit.
IF YOU HAVE 288MM BRAKES TO START WITH
Re: brakes
Posted: Sun Dec 06, 2009 5:57 pm
by GR33NIE
pip_polo wrote:yes the 312mm do fit. and the back also fit.
What is the size of standard front discs on a GT, 288mm?
Re: brakes
Posted: Sat Dec 12, 2009 3:42 pm
by Veedub9n
Anyone got a parts list for convertion standard polo brakes to 312s and converting the rear drums to 256s??
Re: brakes
Posted: Sat Jan 09, 2010 12:05 pm
by g__humm
i have been told that the rear 256 off a tt or golf 4motion will fit as well could you tell me if this is true or if not y not
Re: brakes
Posted: Sun Jan 10, 2010 12:43 pm
by pip_polo
If you have a polo GT or a GTi then you will have 288mm fron discs and what ever the rears are. If you have a 'normal' polo with 256mm fronts or smaller then you will need to change the hubs to them found on the 288mm polo's. Not sure why but something about swapping the caliper carriers. Same again on the rears, if you have 288mm fronts then 256mm will be a straight swap for the back. not too sure about drums, sure someone will know though :)
Re: brakes
Posted: Sun Jan 10, 2010 1:08 pm
by RUM4MO
pip_polo wrote: Not sure why but something about swapping the caliper carriers. Same again on the rears, if you have 288mm fronts then 256mm will be a straight swap for the back. not too sure about drums, sure someone will know though :)
The reason you need to change the front hubs of the "lesser" models is that their calliper carriers are part of the hub assembly - the "higher" models have seperate calliper carriers - so they just need changing to suit the bigger discs - converting rear drums to discs is a bit bigger a task and the handbrake cables also need replacing.
