2 x Alpine Amps + Vibe QB 6x9s
Posted: Fri Jan 01, 2010 9:12 pm
Here for sale are a few bits I was planning on installing in my Polo but due to a change of plan these are now up for sale. I have the following available:
Alpine MRP T220 amp
I bought this a few months ago to power some components. Its new and has only been used once to check that its working. I've lost the box for it but it will be put into a box for postage. The manual for it can be found here http://akamaipix.crutchfield.com/Manual ... RPF240.PDF. More information can be found here http://www.crutchfield.com/p_500MRPT220 ... tml?tp=115.
These retail at £75 - £50 posted
Alpine MRP F250 amp
I bought this with the other amp to power the Vibe speakers. Again, this is new and I've only wired it up to check it works. I've lost the box for it but it will be put into a box for postage. There are also two covers which should go over the sides to cover the terminals, but these were in the box. There only there for looks and dont affect the operation of it but this is reflected in the price. The manual for it can be found here http://akamaipix.crutchfield.com/Manual ... RPF250.PDF More info can be found here http://www.crutchfield.com/S-Tz88sPk0cU ... -F250.html This can be used to power a pair of speakers and then bridge the other 2 channels to power a sub and has many functions but please refer to the link for detailed specs.
These retail at around £130 - £60 posted
Vibe QB69 Speakers
These are extremely powerful speakers with 600w of power. Info from a website - "They have a unique rectangular design providing 20% more cone surface area than a regular 6x9, resulting in greater air movement and increased bass response. The QB69 remain one of the most sought after speakers on today's car audio market. A subwoofer motor structure is used to power the ultra stiff rectangular IMPP cone which is suspended in a radically designed light grey butyl rubber suspension surround to produce precise lateral cone movements, delivering low to no distortion and clean PowerBass™. The crossover is precisely attuned to the exact specifications of the speaker, finished in a compact package the crossover is easily hidden away or would look equally neat on display. Exceptional midrange performance of these speakers is produced by the oversized aluminium tweeter diaphragm which allows an ultra extended high frequency response. Oversized terminal posts with screw down clamps make it possible to fit larger speaker cable directly to the tinsel wires. A new revised and unique grill design makes the speakers a much more attractive choice; the new grill protects the speaker whilst showcasing their unique attributes and styling."
They are boxed and come with the owners manual, the 2 speakers, the 2 crossovers and all associated wiring and also mounting screws and fixings.
These retail at around £150 - £65 posted
I also have the parcel shelf out of my Polo GTi which has a set of Pioneers in it, these are knackered hence puirchasing the Vibe speakers orignally. This can be used so you dont have to chop your standard parcel shelf - £25 posted (without the Pioneers as makes it lighter to post)
Any questions feel free to drop me a PM or text me on 07825524674
Alpine MRP T220 amp
Alpine MRP F250 amp
Vibe QB69 Speakers
