Page 1 of 2
passanger window jamming- bouncing back down
Posted: Mon Jan 25, 2010 11:34 pm
by S.Kayani
wondered if it was a common prob
sometimes the window doesnt come up - or comes up really slow - or requires some help - or sometimes it just bounces back down when putting it up...any ideas whats up with it?
Re: passanger window jamming- bouncing back down
Posted: Tue Jan 26, 2010 11:19 am
by neilGTI
This used to happen on mine just before the window regulator snapped
Posted: Tue Jan 26, 2010 1:21 pm
by 6N2 GTI 00
My Driver Side window currently has the same problem and a quick fix solution is to grease the window seals. This cured my problem for around 4 months but its only temporary and once the grease wears off it will need doing again.
It will require a new regulator but you can put that off with the grease which is exactly what I did.
If you really want to cure the problem though you will need to get a new regulator from Volkswagen or VAG parts etc
Ben,
Posted: Tue Jan 26, 2010 7:58 pm
by alexperkins
no more vag parts
they went bust last year!
Posted: Wed Jan 27, 2010 8:07 am
by neilGTI
I managed to fix my regulator when the clips snapped myself.
Pretty easy fix to be honest, just 2 screws and two washers. Its stronger than a new one from VW and has been "fixed" for over a year now with no problems.
Posted: Thu Jan 28, 2010 12:35 am
by S.Kayani
sounds like it could be the regulator? where do i find that?
might try greasing it, if that dont work, or it snaps might try the repair...any ideas on a price for a new one?
Posted: Fri Feb 12, 2010 6:21 pm
by supermico
Yeah, seems like a pretty common problem. mine used to do it, I solved it with a zip tie
The window fell off one of the plastic clips on the window guides, causing the window to come up at an angle. I just placed the window back onto the clip and secured it with a ziptie...
Posted: Sat Feb 13, 2010 3:47 pm
by S.Kayani
door card off job to access the motor/clips??
Posted: Sun Feb 14, 2010 12:54 pm
by supermico
Yes, you have to remove the door card. It's an easy job, though. two screws on the handle and its just clipped on from there on.
Posted: Tue Feb 16, 2010 11:59 pm
by S.Kayani
nice, ill give it a try once the weather gets a bit better!
its not too bad at the min (windows always shut! lol)
Posted: Wed Feb 24, 2010 9:39 pm
by dantheram
supermico wrote:Yes, you have to remove the door card. It's an easy job, though. two screws on the handle and its just clipped on from there on.
where are these screws?
Posted: Thu Feb 25, 2010 8:39 am
by alexperkins
under the front plate of the door handle. You need to carefully lever it off by getting a screwdriver and putting it in the gap where the door pull and the plastic meet. There is also a screw in the top corner closest to the front of the car which needs undoing.
Posted: Thu Feb 25, 2010 5:25 pm
by dantheram
found a guide on this site somewhere with all the info on. Cheers anyway Alex
Posted: Thu Feb 25, 2010 5:34 pm
by alexperkins
i was gonna link to the guide lol i just couldnt be bothered to open another tab
Posted: Thu Feb 25, 2010 9:31 pm
by supermico
alexperkins wrote:There is also a screw in the top corner closest to the front of the car which needs undoing.
Oh yeah, I completely forgot about that one. Caused me a couple of braincells when I tried to pull my door apart and it wouldnt go:D
