rear speakers
Posted: Wed Mar 03, 2010 10:33 am
by matty
got some rear speaker covers from dealer - 3.80 each and fitted them into the rear door panels for the gamma radio of the 2 door polo 9n
Re: rear speakers
Posted: Wed Mar 03, 2010 5:53 pm
by g__humm
how hard was it to do mate??
Re: rear speakers
Posted: Wed Mar 03, 2010 9:48 pm
by matty
was quite easy, take the quarter panel off and on the rear side score it with a 2 1/2inch hole cutter being careful not to cut through the fabric with the hole cutter as it will pull the threads on the front, cut the fabric into quarters and push to the rear glue down if you like but the speaker cover is quite a tight fit, connect speaker, i used a passat rear little tweeter - quite loud - and just glued it on the back, an original one is about 15.00 from vw. on the panel their is a bottom speaker cover - these are blanks on some models mine was a blank and i fitted speakers into that bit aswell. had to run wiring from the head unit to the back down the panels. the rear bottom speaker is the same as the front door speaker.
all working sounds mint
matty
Re: rear speakers
Posted: Tue Mar 09, 2010 11:57 am
by MGrove03
Whats the part number
6Q3 868 149 A ??
And would they sit flat against the rear 2 doors of a 5 door polo??
Re: rear speakers
Posted: Wed Mar 10, 2010 9:09 am
by alexperkins
MGrove03 wrote:Whats the part number
6Q3 868 149 A ??
6Q3 868 149 A 71N
