Page 1 of 2
car is whining??
Posted: Thu Mar 04, 2010 7:38 pm
by S.Kayani
on the drive home today, felt the car jerk then all of a sudden its started making whining noises, was only 2 mins away from home when it happened so just parked it up at the min
wonder if its the gear box? or something else?
it was driving okay i think - maybe reduced power a little?
stops making the noise when its in neutral
Re: car is whining??
Posted: Thu Mar 04, 2010 7:55 pm
by alexperkins
does it go away when the clutch is depressed or is it there all the time?
Posted: Thu Mar 04, 2010 8:01 pm
by S.Kayani
i knocked it in to neutral, an it doesnt make a noise, havent tried it with clutch down yet - its had a new clutch bout 1-2000 miles ago
Posted: Thu Mar 04, 2010 10:21 pm
by dantheram
mine has a very slight wine after i had a new gear box, its most audible when under engine breaking. no idea what it is.
Dan
Posted: Thu Mar 04, 2010 10:46 pm
by S.Kayani
this whine is very loud, gona go garage in the morning an get it checked out...
Posted: Fri Mar 05, 2010 9:22 am
by BobbyG
I have a slight whine but only in third, other than that no problems so I'm not concerned
Posted: Fri Mar 05, 2010 11:59 am
by 6N2 GTI 00
This may sound a little out of place but there is a slim chance is could be the cambelt tensioners.
When mine went early last year it started to make a very distinctive whining sound which at the time I thought might of been the power steering but it turned out to be the tensioners.
Its very unlikely that it will be your tensioners but I wouldnt rule it out either
Ben,
Posted: Fri Mar 05, 2010 4:36 pm
by S.Kayani
the car drives ok, goes in an out of gear fine, but makes the noise whilst in gear an even whilst in neutral!
took it to garage, he said its deffo the gearbox!
any ideas on a cheap place in nottingham!!?!
Posted: Fri Mar 05, 2010 5:48 pm
by dantheram
gearbox = costly, you're never going to get it done cheap, if you do it'll probably be s**t.
Posted: Sat Mar 06, 2010 1:46 pm
by S.Kayani
true, booked in for monday morning to get checked, gonna see how it goes!
Posted: Sun Mar 07, 2010 10:18 pm
by alexperkins
sounds like diff bearings .... mine had the same problem, and had to have a full box rebuild
Posted: Sun Mar 07, 2010 10:42 pm
by S.Kayani
how much that set u back mate?
mines goin in tomorrow morning, if i got a rough price in my head then i know hes not ripping me off lol
Posted: Sun Mar 07, 2010 10:44 pm
by alexperkins
Box rebuild was about 400ish from memory plus labour
Posted: Sun Mar 07, 2010 10:51 pm
by S.Kayani
what you reckon around 600ish all in??
Posted: Sun Mar 07, 2010 10:53 pm
by alexperkins
probably about that ye
