Lamba Probe/Oxygen Sensor faulty?
Posted: Mon Mar 22, 2010 2:53 am
by kraized
Hello. My 'Engine Check' light is on, on my GTi 6N2 dash. I've got really bad performance with lots of juddering while under acceleration and when idle. After a bit of Googling and what not I suspect this is a problem with the Lambda Sensor. Is this more or less what the problem could be or is it something more serious like the CatCon (which I'm hoping it isn't)?
Re: Lamba Probe/Oxygen Sensor faulty?
Posted: Mon Mar 22, 2010 11:11 am
by tegwin
Could be a massive number of things.... get it plugged into Vag-Com and find out exactly what the issue is
Posted: Mon Mar 22, 2010 6:35 pm
by emma_88
Yeah, as tegwin said it could be a number of things.. Get someone local with VAG-COM to plug it into your Polo.
However, I currently have the exact same problemabd my VAG-COM results are showing that there's a fault with the lambda - It's probably just the connections or something, I'm hoping.
