FAST ROAD CLUTCH FOR A 6N2 GTI
Posted: Wed Apr 21, 2010 12:05 pm
by wheelmanwayne
im in need of a clutch and im in need pretty fast!
been looking at TECHNICLUTCH FAST ROAD CLUTCH KIT does any body know if they are any good ? or can anyone suggest a good reliable clutch kit to use??
many thanks peeps
Re: FAST ROAD CLUTCH FOR A 6N2 GTI
Posted: Wed Apr 21, 2010 12:30 pm
by 6N2 GTI 00
Not too sure on the Techniclutch kits but most people on here tend to go for the Sach Cluthes as a direct replacement.
Their really good value for money too
Posted: Wed Apr 21, 2010 12:39 pm
by wheelmanwayne
does any body have a part number for the sachs kit? thanks
Posted: Wed Apr 21, 2010 1:03 pm
by emma_88
I've never heard of the Techniclutch kit before.
Get the SACH clutch from GSF!
GSF No: R-620306100
Part No: 3000-581-001
Posted: Wed Apr 21, 2010 1:32 pm
by MrP
Do NOT buy a techniclutch kit.. Just google them and look at some of the forums they are mentioned on.
Apparently very bad pieces of kit.
Posted: Sun Oct 17, 2010 12:12 pm
by Petar001
Hi m8
i have bought TechniClutch kit for my polo gti and i expensive delivery and customs because i am from Croatia !
after only 5000Km it is arround 3000miles my plate brokes and i had left without gears i had to change gears without clutch
btw my old LUK clutch set was in my car for 40 000 km no problems only it was a little hard
then i put that old clutch and send TECHNI s**t back to UK for warranty claim
and then after 1 month of waiting they told me that is not manufacture error that is problem with my gearbox with
here is C/P
Dear Petar, we have spoken to the warranty department. To clarify and go into a little bit more detail, the clutch driven plate was not being released or clamped evenly due no fault of the clutch; this is evident by the photos you were sent yesterday showing the unequal wear on the diaphragm fingers. If a driven plate is not released or clamped evenly then one side of the friction material will be clamped/ released before the other, the downward and upward forces will not be equal on either side putting more pressure on one side of the friction material than the other. In your particular case, the driven plate did very well to put up the unequal pressures for as long as it did but eventually tore the friction material off as you know. You are of course welcome to verify this with any clutch specialist.
We can understand you being upset but please be assured that this was no fault of the clutch. We are unable to give you a refund as there was no manufacturing defect. The pressure plate and release bearing are both in a serviceable condition albeit used; we would recommend that you purchase a new driven plate to go with the pressure plate and bearing to make a serviceable kit up again; we are prepared to send the kit back to you free of charge as a gesture of goodwill if you decide to go down this route.. You do need to replace your clutch release arm as soon as possible in any event as with time this problem will recur with your new clutch.
Regards
Then after one month more they told me that they will give me NEW plate and bearing BUT old pressure plate i said ok
they told me that they will send to my address
after one month NOTHING i am sending mails NOTHING no answer now it is 2 month after last mail from them !
so my opinion is NOT TO BUY THAT S...
