Boost Gauge - Wiring
Posted: Tue Apr 27, 2010 9:04 pm
Guys I need a bit of help. I have no issue installing the boost pipe from the engine bay as I am following the guide in DIY section
http://www.uk-polos.net/view ... 00&start=0
My issue is on the wiring part because am no expert in wiring and dont want to f**k up the GTI lightswitch loom so need some guidance.
In the write up it shows how to wire up a SWG Gauge but I dont like the look of them so went for the 'Auto Gauge' smoked version.
Now basically I would like the gauge to switch on once the ignition is switched on with the key and am not sure which wire is the ignition live?!?!
The wire connector, which I got with gauge has four wires in the loom which basically connects from the gauge to the lightswitch loom:
RED: Battery (+12V)
BLACK: Engine Ground
WHITE: Ignition Switch 12V+
Orange: Dimmer/ +12V To Dimmer
Now, here are the pictures of the GTI lightswitch loom which I took:
If it would be possible could somebody please please advice me on how to wire up this?!?!
Also if it could be possible please add lines to indicate which wire is what or which should be connected to what.
RED: Battery (+12V)
