UK-POLOS.NET - THE VW Polo Forum • Polo Mk4 1.4cl 80mm drop on 195/45/15's ???
Posted: Tue May 04, 2010 12:53 pm
by sweetinglooney
Is the above good to go?
Seen some springs + shocks on ebay at a good price, they lower front and back 80mm, but don't want to but unless i no i aint going to get any issues?
Also how easy are springs to fit (are they the same process as fitting coilovers?)
Any help would be much appreciated.
Re: Polo Mk4 1.4cl 80mm drop on 195/45/15's ???
Posted: Tue May 04, 2010 8:26 pm
by Sonic69
thats a tidy drop m8 , i droped mine today on coilovers around 90mm on the front and 80mm on the back (with no helper springs)
and it sits liek this ..
and yeh Springs are same as coilovers, top mount off undo the 2 bolts at the bottom of your shock then remove old springs and put in ur new ones and do it all back up :)
Posted: Thu May 06, 2010 10:17 am
by sweetinglooney
Looks sweet mate.
Did you fit the coilovers yourself?
I have been told there is a special tool you need to undo top mounts???
Been quoted £80 from garage to fit, but if i can save this by doing myself i will do.
Posted: Thu May 06, 2010 5:34 pm
by 16vMoose
i fitted my coilovers myself and yes u need a 21 or 22 spanner which dips down, can't remember what they're called, for the top mount
Posted: Fri May 07, 2010 9:06 pm
by Sonic69
yeh fitted it myself , i used a Spanner + Allan key head on a ratchet for the top mounts :) worked good for me dude , took me 3 hours dude.
