gti cutting out?
Posted: Sat May 08, 2010 6:50 pm
by Minstral
recently my 6n2 gti has started cutting out for no reason. yesterday i pulled up to some traffic lights stopped and it just conked out. wouldnt start straight away and the battery light came on. waited about 30 secs came back on, then about 20 yards down the road exact same thing happned.
on the way to work today it was fine then on the way home done it again although this time it was whilst i was moving. have had a look at vag com 2 days ago says about the lamda sensor' but wouldnt have thought this would effect it. ive had no ecu lights or anything only the battery when it just randomly stops
Re: gti cutting out?
Posted: Sat May 08, 2010 7:44 pm
by Minstral
ive put 2 of the codes in ross tech and 1 the results says the engine speed sensor (no signal), symtons are engine shuts off. says at the bottom this can also be a result of the crankshaft position being wrong
if anyone can tell me were this is located on the gti then i can see if its something i can do myself
Posted: Mon May 10, 2010 11:23 am
by emma_88
The crank sensor is located to the back of the engine - I've got a crank sensor to change on mine.
It's a bit tricky to get to, basically you need to take the inlet manifold and the started motor off to get to it. So it's not a quick 5 minute job.
Out of curiosity, what was the other fault code?
Fine for Parking
Posted: Mon Nov 08, 2010 10:33 am
by caomom830
Tell me again," asked the judge, "why you parked there?" The driver rose and answered respectfully, "Because, Your Honor, it said 'Fine for Parking'" pay some money for doing something wrong.
[font=Arial][/font]
[font=Arial]No [/font][font=Arial]money[/font][font=Arial] no way in real life,no [/font][font=Arial]gold[/font][font=Arial] no way in game![/font]
Posted: Sun Mar 27, 2011 11:35 pm
by idan
EGR!
