UK-POLOS.NET - THE VW Polo Forum • clunking sound over uneven road?
Posted: Tue Jul 13, 2010 12:25 pm
by benmkiv
ive been told it may be the top moutns for the susp,
its not coilys but i believe its sitting on 40mm springs, any advice or know how?
Re: clunking sound over uneven road?
Posted: Tue Jul 13, 2010 6:02 pm
by Gary Gee
Or could be popped shocker...
Bounce each corner and see If ones squishyer than the others
Posted: Tue Jul 13, 2010 11:56 pm
by Adam-
Springs moving around (or lifting off the mounts) when they encounter an uneven surface?
Like, they lift out their mounts for a second as the car raises, then fall back into place?
Posted: Wed Jul 14, 2010 1:46 pm
by benmkiv
not a top mount, checked those yesterday dont thuink its popped shocker either also checked that, they all seemed pretty solid.
i think its jst the fact its running on springs.
i think turn up the music louder i cant hear it :)
Posted: Wed Jul 14, 2010 4:07 pm
by RS_GT
benmkiv wrote:not a top mount, checked those yesterday dont thuink its popped shocker either also checked that, they all seemed pretty solid.
i have coilies on and they were clunking due to the top bolts not being tight on the back
also when you jack the car up, can you move the springs around at all?
Posted: Wed Jul 14, 2010 4:15 pm
by Adam-
He said he's on springs, so i don't think that's an issue? Unless the springs are too short and bouncing out their mounts like i said?
How d'you stop the springs falling out when you jack the car? The guy never sent me the helper springs (I'm assuming that's what they're used to do?!)
Posted: Wed Jul 14, 2010 4:25 pm
by RS_GT
Adam- wrote:He said he's on springs, so i don't think that's an issue? Unless the springs are too short and bouncing out their mounts like i said?
Im sure the top mounts still got to be tight regardless of what suspension he has, maybe when the springs were fitted it wasnt tightened properly
theres not much you can do if the springs fall out,just means your springs are too short for the shocks. im sure helpers are only for coilovers though :?
