Wheel damage
Posted: Sun Aug 22, 2010 5:59 pm
by countryman
Good evening people.
Made the silly mistake of driving against/over a high kerb today at around 15 -20mph :| and damage the tyre and the wheel. Lucky enough they are not alloys and the tyres were just about needing replacement.
My question is, will I need to replace the wheel and if so where do I go about trying to find a replacement?
Thanks in advance
Re: Wheel damage
Posted: Sun Aug 22, 2010 7:11 pm
by alexperkins
if you have bent the steel rim, then yes its best to replace. scrap yard is the best place to be fair - pick it up for pennies
Re: Wheel damage
Posted: Sun Aug 22, 2010 7:33 pm
by countryman
Thanks for the reply. I was swerving to miss a pot hole at the time and just hit the kerb, annoying.
Are all steel rims the same, as long as its the same size?
also when it happened I popped the spare wheel on and noticed the car is pulling to the left. is it possible there’s further damage. steering Rod?
Re: Wheel damage
Posted: Sun Aug 22, 2010 7:34 pm
by alexperkins
Youve probably affected the tracking of the car - take it to a wheel place to get it realigned.
That steel is a deadun. Any 4x100 13" VW steel will do. Ideally a like for like is what you want such as a mk3, mk4 or mk5 polo one
Re: Wheel damage
Posted: Sun Aug 22, 2010 7:45 pm
by countryman
a ok thanks. got the day off work tomorrow, will be a good time to sort it out. hopefully that is all that will need repairing!
Re: Wheel damage
Posted: Fri Aug 27, 2010 1:59 pm
by benmkiv
i did this to one of the steelys on my old corsa
i never got it changed though didnt seem to make any difference
it was probably completely unsafe though :P
Re: Wheel damage
Posted: Sat Nov 20, 2010 7:14 pm
by countryman
Rather a very late reply, but got a replacement wheel the next day for a tenner. And had tracking done, solved all problems!
Re: Wheel damage
Posted: Tue Nov 23, 2010 9:21 pm
by bradley1983
the wheel.........hit it with a hammer, would bend it back.
£10, cant complain tho.
