Page 1 of 9
FAO 1.0ltr and 1.3ltr engine owners!(single point injection)
Posted: Thu Apr 29, 2004 8:08 pm
by SpikeyG40
hey there guys
as some of u no, i have made myself an induction kit out of mk3 golf parts! this is all good, however, i did come across a few problems with the job!
to fit the new inlet (bit which sits on top of the injector) u need to remove the three studs which held on the old air box (the round, pancake style one). however, when i came to do this, we couldn't remove the studs! now there is a problem!
after a lot of hard thinking, i had an idea of making up some bolts which had a drilled and tapped hole in the end which would screw onto the existing studs. this also means opening out the holes in the new golf inlet which means taking out a sleave which is in the holes!
it all now fits fine and works a treat (but has a little bit of teething problems with the hot air feed vaccum! no idea wots going on ther)
now i have had some interest in the induction kit, but not everyone has access to a mill and a lathe which u need to produce the kit!
so basically, i was wondering how many people are interested in having an induction kit and if enough interest is made, i would be willing to help produce it!
by the way, i'm taking it off this weekend for the MOT, so i'll get some pics for ya!
regards
doug
Posted: Thu Apr 29, 2004 8:26 pm
by KarlM
I may be.... can you give an estimate on price?
Posted: Thu Apr 29, 2004 8:44 pm
by SpikeyG40
well i'm not really sure at the mo, seeing how much interest there is, plus would the inlet be bought brand new, or would i have to find em at the scrappy? still quite alot to think about but would like to see wot people think!
Posted: Fri Apr 30, 2004 8:35 am
by Gobert23
I've got a 1.3CL with the single-point injection set-up. I'd certainly be interested... I've been tryign to source a decent filter/induction system, but with no luck so far.
I'f you send me some pictures of the parts that you're using, I'll try and track some down at the local breakers. The local breakers turnsaroudn quite a few Veedubs, so I might be lucky and get what's needed for the kit.
Greg
Posted: Fri Apr 30, 2004 10:10 am
by Gareth_GT_Hatch
Theres a pic of the setup in the mk3 picture post at the top. I hope youve got a fast connection though cos its right near the bottom. My browser gave up at work (ISDN) but I Was ok at home (Broadband)
Posted: Fri Apr 30, 2004 10:13 am
by SpikeyG40
the pic at the bottom of the pic post is my car! thats how it looks, i'll get some more detailed pics on the weekend of how it fits etc.
Posted: Fri Apr 30, 2004 10:16 am
by SpikeyG40
thought i'd find the pic so u don't have to find it urself!
http://www.angelfire.com/punk4/doug_and ... filter.jpg
Posted: Fri Apr 30, 2004 10:30 am
by concept-e
yep, definitely interested mate. How much is the key question!!!!
Posted: Fri Apr 30, 2004 12:17 pm
by Gobert23
Yip, count me in as well... It's certainly a hell of a lot better than the biscuit tin that's fitted as standard.
G
Posted: Fri Apr 30, 2004 12:33 pm
by LogIK
You obviously know that I'm interested, since this post was our idea :D
We need to get about 10 people interested before this can go ahead. Another problem that we face is sourcing all those MK3 Golf airboxes. The cheapest option would be to aquire them from a scrapper, but this would obviously cause problems with availability etc, so what about doing a batch group buy with a supplier to get a discount.
Firstly, before we do anything, we must see how many people are definately interested. We have four people up to now:
Me
Gobert23
concept-e
KarlM (possibly)
A price will be able to be determined once we find out how many people are interested.
Thanks.
Posted: Fri Apr 30, 2004 2:50 pm
by DanW
I might be able to source some air boxes from my local to help out. Just get me some pictures up and I'll see what I can find. Oh and some instructions on how to quickly remove them *thumbs up*, I don't wana be at the scrappies for ages trying to get em of when it only take like five mins.
Any way I can make one for a multi-point?
Posted: Fri Apr 30, 2004 3:16 pm
by Gareth_GT_Hatch
Why would you want to?
Posted: Fri Apr 30, 2004 3:48 pm
by LogIK
You don't need to, mate. The whole point in this experiment is to enable us "single pointers" to have an induction kit and get rid of the round airbox for improved airflow. Since you have a multi-point injection (NZ) all you need to do is stick a cone on the end if you want an induction kit.
Posted: Fri Apr 30, 2004 4:06 pm
by optima21
before deciding if an induction kit is necessary, you should be looking at the restrictions in the intake system. I havnt got a spi model, but if you look at the throttle body you will probably find that the bore is much smaller than the snout bit on the end of the standard air filter housing, in which case you wont realisticaly be able to flow any more air and a better be might just be to use a high flow airfilter in the standard housing, or take the snout off (to just before the hot/cold air flap) and use some tubing to get some air from behind the grill etc.
if you look at a 1L mk2 (like I've got) and remove the snout from the airfilter (roughtly the same as the mk3 item), you'll find that its got a 50mm bore. The carb has a 32mm bore, so already the airfilter housing can flow nearly 2.5 times what the carb can take, so its not the air intake and filter assembly thats the problem, but the carb.
Posted: Fri Apr 30, 2004 4:19 pm
by DanW
I just wanted to get some more power under there. Something simular to the unit, not the same. But then again, thinking about it, making the air inlet a bit bigger, or getting a new air filter could improove it some what.
:roll:
