help needed
help needed
Can any 1 help i need to now wat are the best lowering springs to fit a 95 1.4 8v i want a drop of around 60 - 75 mm and if there is any additional work other than fitting the new springs ????
Reason: removed oversized bright red text to make it easier to read
Re: help needed
How much do you wanna spend mate?
If you can afford around £170, just get some coilovers!
They'll be adjustable from 30-120mm so you can get it sitting perfect.
Also fairly easy to fit, and that's all you need!
Re: help needed
ye i can , i have no idea which to get im new to moddin dubs what wud u go 4 ?? i dont wana spend much more than 200
thanks for the reply fella
Re: help needed
Get a set of FK's or Ebay ones, either branded HotTuning or TK(something!).
If you get a garage to install them, coils would be cheaper labour than spring scos the shocks and springs are already together!
Re: help needed
Yeah definitely go for some coilovers then mate! and like NOZ said get FK's or search 'Polo 6n coilovers' on Ebay. They're usually around £170 on ebay and if you can't fit them yourself a garage will charge around £100 to fit them.PITCHERSPOLO wrote:ye i can , i have no idea which to get im new to moddin dubs what wud u go 4 ?? i dont wana spend much more than 200
