No reversing lights Any Further Ideas
Posted: Fri Oct 22, 2010 7:56 pm
by dulux72
Hi Guys
Newbie so be gentle
2002 1.2 12v
No reversing lights
I have swapped the switch with one known to be good but no change.
Does any one have any ideas of where to start in trying to sort this
Re: No reversing lights Any Further Ideas
Posted: Fri Oct 22, 2010 10:58 pm
by POLOZ
Have you checked the bulb? Also make sure to check the fuse. The fuse box is located on the offside beside the dash.
Posted: Fri Oct 22, 2010 11:03 pm
by zedzo
its usually the switch mines gone plenty of times, try another. there maybe fuses to check them. and finally your bulbs
Posted: Sun Oct 31, 2010 1:55 am
by RITCHAT
check for corrosion in the plug that connects to the switch and also the rear boot connections that are on the left handside of the boot on the wheel arch as vw in their wisdom have the rear wash wipe pipe connection right on top of the wires /connection block.
Posted: Fri Nov 05, 2010 7:38 pm
by CharlesK
My 1.4 sport has the same problem, nightmare in a car park, people won;t stop to let you out before they can't see a reverse light.
Where's the sender located?
Posted: Sat Nov 06, 2010 9:39 pm
by Veedub9n
When they went on my old polo it was becasue the clip that connects to the bottom of the gear stick came off.
